in this video, I want to ask, I tried to operate the drone on a straight road according to the video, with the right stick I continued to control the stick in an upward direction, but at some point the drone slowly headed to the right side which made me have to shift it to left side back.
why is that happening? I feel very different operating the DJI AVATA with the DJI Air 2S. This dji avata is my first fpv drone, and it's my first time trying to fly it.
note : to be honest, on the 2nd day i get this dji avata, i did to put the accessories which (Sunnylife Motor Protective Cover Scratchproof Aluminum Alloy Motor Caps Anti-dust Accessories for DJI Avata)
after that, i've got notification like esc error propellers, so I decided to uninstall it again and chose not to install these accessories, and afterwards there were no errors like at the beginning. is there any effect because of that?
The Avata really struggles with even light wind, so that's one possible culprit. The Air2S is an absolute rock in the wind, so it can be jarring to see the difference between it and the Avata.
Hi, Aerion Sky. Thank you for reaching out. The Motor Caps above are not recommended accessories for the DJI Avata and since you received an ESC error after installing it, there's a possibility that the accessories were the ones that caused this problem. Please consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support.
2wheeledphotog Posted at 1-20 18:26
DJI Gamora Posted at 1-22 19:57
Hi, Aerion Sky. Thank you for the update and we're sorry for the inconvenience. Please contact DJI support at (https://www.dji.com/support), they will be more than happy to provide about the repair process in your location. Thank you for your kind understanding.
