Where to post Mini 3 pro messages?
586 3 2023-1-22
fans4b89104f
Where is the proper place to post messages concerning the Mini 3 Pro?  There is no matching category under Products.  The closest one is Pro Systems but someone has already been warned that is not the correct section for Mini 3 Pro messages.
Perhaps I'm not seeing all the choices?  All that is listed under Products at my end are:
Mavic
Osmo
FPV Series
Spark
Tello
Accessories
Pro Systems
App
RoboMaster S1
2023-1-22
DJI Diana
Flight distance : 2408 ft
Hi there. Sorry if it made you confused. Under the "Products" selection, please hover and click on "Mavic". You will then see the selection on the top page and "Mini 3 Pro" should be there. Hope this helps. Thank you.
2023-1-22
djiuser_Pd1cP6GOEpXP
Uruguay
Hello, my mini 3 pro connects and disconnected constant, a 1 meter distance between the mini 3 pro drone and the control of the RC screen. This happened after the Ultona Firmware Actulization I did. Is there no hay any solution for this yet? Does that happen to someone else?
2023-2-27
DJI Wanda
djiuser_Pd1cP6GOEpXP Posted at 2-27 12:03
Hello, there. We have replied to your post here:
https://forum.dji.com/forum.php? ... 875&pid=2991020
We will delete your other duplicate threads.
2023-2-27
