I am more or less at my 5th or 6th flight never encountered such issue, and now - even though I have not lost my mini 3 pro, it smashed into a wall after lost of control. Set to avoid obstacles, I did my usual auto take-off which normally lift the drone of 1.5 meters and have it wait for firther instructions. Today, after lifting and absolutely NO JOYSTICK MOVEMENT on my part, the drone escaped from its space and flew away with absolutely no way for me to control it.
Eventually, as I was running the streets to make sure it was not landing anywhere, my son was able to retake control for a while. Once near its starting point, the drone lost control again and smashed into the wall of the building at about the 4th or 5th floor and falled on its back, slightly opened (top) with a piece slightly coming out and some wings damaged.
Now, as I am trying to see if it connects to the RC, I get an alternating message (non-stop) between
- Incompatible gimbal data - Preparing to take off
On Flight checklist (appears in following order on the list): -Gimbal unable to connect. Repairs required. Contact DJI Support for assistance (Code: 1d030001) -IMU initializing. Retrieving IMU data (Code: 16100009) -IMU initializing. Retrieving IMU data (Code: 1610001a) -IMU not calibrated. Calibrate IMU (Code: 30055) (appears impossible to do....) -Aircraft missing parts. Repairs required. Contact DJI Support for assistance (Code: 1610004b) -GPS signature info not found. Repairs required. Contact DJI Support for assistance (Code: 16100071) -GPS module not detected. Repairs required. Contact DJI Support for assistanan(Codne1<100024)
It was purchased on Amazon MX and only option I have is to return it for reimbursement (no way to exchange). Only a few days left on my Amazon Prime conditions.
Anyone saw such problem before ? I have no idea if there are DJI authorized repair shops in Mexico, so I see no other solution but to return and purchase a new one once reimbursed.
Not sure I want to just auto-repair by pushing the piece I see coming out and force closing of the top....
I see no explanation but bad and unreliable batch.
