DJI Gamora
Hi, ggofly_dronemedia. Thank you for reaching out and we're sorry for the inconvenience. Please try the recommended troubleshooting steps below (skip the step if you already performed it):
1. Press the Power button once to check the battery level. Ensure that the battery level is sufficient.
2. After connecting a power cable, press once and then press and hold the Power button to power on. After powering on, if the power cable is removed, the battery will power off automatically.
3. Ensure that the power level is sufficient. After connecting the power cable, press the Power button again, or use another power cable. If the issue persists after several attempts, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support. We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support. |
