DJI Mini SE
389 3 2023-1-27
Gudz01
I need help finding batterries fro my drone. Hopefully something that is also compatible with a the hub. NEW to this so would appreaciate the help
2023-1-27
DJI Gamora
Hi, Gudz01. Thank you for reaching out. This is the compatible Intelligent Flight Battery for Mini SE:
(https://store.dji.com/product/mi ... esult-v2&position=3). Hope this helps. Thank you for your support.
2023-1-27
Gudz01
DJI Gamora Posted at 1-27 18:50
Hi, Gudz01 Thank you for reaching out. This is the compatible Intelligent Flight Battery for Mini SE:
(https://store.dji.com/product/mini-2-intelligent-flight-battery?from=search-result-v2&position=3). Hope this helps. Thank you for your support.
Thank you!!Does this mean every othe Mini 2 accessory is compatible with the SE ??
2023-1-31
DJI Gamora
Gudz01 Posted at 1-31 13:39
Hi, Gudz01. You're most welcome! The battery, propellers, charging hub, and 360° propeller guard of the DJI Mini SE and DJI Mini 2 are interchangeable.
2023-2-3
