DJI Tony
Hi there. Thanks for notifying us about this concern. We apologize for any inconvenience caused. The near-ground altitude is the combined altitude of the barometer and GPS. The barometer is easily affected by unstable low air pressure, air temperature, and other factors. This can lead to a deviation in the barometer metered altitude. The GPS altitude is also affected by accuracy, which can lead to an error with the near-ground altitude. However, this does not affect flight performances. To improve altitude displays, you may refer to these recommendations:
1. Land the aircraft and take off again. At this point, the flight controller will recalculate the aircraft's altitude relative to the takeoff point. This can improve display accuracy.
2. Do not fly the aircraft forcedly in a vertical direction (Repeated rapid ascending and descending will lead to a larger altitude error). This can improve display accuracy.
3. Calibrate the IMU.
Should you have further concerns, please reach back here at DJI Forum. Thank you, and have a nice day. |
