gnirtS
Flight distance : 5712575 ft
Really does depend on your subject and what your output format is.
Higher frame rates are useful for faster motion and will produce less stuttering. Can also be used to produce smoother slow motion shots.
25/30 were the old style TV frame rates for world and USA regions. You can get flickering of artificial lights if you pick the wrong one here (50 or 60hz mains).
24 is "cinematic" although in reality there's no different at all anyone can see between 24 and 25.
If following the 180 rule then you need more light for the higher shutterspeeds required for 60fps. On the other hand, if you have low light then the lower FPS are going to work out better as they need a stop or so less on the shutter to provide the blur.
A LUT is a colour correction layer to produce more accurate colours and contrast from Log footage. D-Cinelink is sort of similar. That said, Cinelike is seconds to correct just using curves. Its not log.
