FlappyBird
Glad you have it fixed! I hope it stay's that way.
I have an suggestion for everyone that don't have a spirit level. Any contained water surface is always perfectly level. You can't have it 'more' level than that.
Take a bowl, large in diameter, as larger as better, but not very tall. I took my wife's flan-pan for doing this. Place the bowl or whatever container in the center of the surface you want to do the leveling on. Fill it with water to a level where it just so not overflows the rim. Inspect the water level distance to the rim. it should be all around the exact same distance. If the water is beginning to go over the edge on one side but on the opposite side you see a distance from the water surface to the rim edge, then you need to adjust your surface until the water is exactly the distance from the rim edge all around.
I used a flat concrete slap and put bricks under each corner. Then I put pieces of plastic sheets between the bricks and the concrete slap until it was level. using a concrete slap also has the advantage that it doesn't matter if you spill some water. Oh yeah, I did that outside away from anything metallic. Make sure there is no reinforcement in the concrete slap. If in doubt, use a wooden board :-)
When it's level, use it to calibrate your Phantom. |
