Hydrolysis (sticky plastic) destroying DJI Products?
1906 13 2023-2-17
alloffroad
Flight distance : 7032454 ft
Has anyone else noticed Hydrolysis happening on their DJI Products? I made a video about it , but at the time did not see DJI products affected until today. I'm getting ready for a filming trip and notice that all three of my 3 Osmo Pockets show early signs off my MyPocker 2 more so than my two Pocket ones.
I'm not talking about general wear and tear, but rather a reaction of the "soft" plastic feel parts of the gimbal with the environment. This really is a manufacturing issue using incorrect materials and is plaguing quite a few manufacturers.
https://youtube.com/shorts/pTVibAMLGAY
Is anyone else having the issue?
2023-2-17
DowntownRDB
Flight distance : ****
I have seen this happen several times in the past on what I call soft touch type of plastic products.  A friend of mine who is a Chemical Engineer said that it is caused by separation of the materials it is made from.  He said it can also be caused from oils off our hands.  Best course of action he recommended was to wipe it down with isopropyl alcohol after each use.  I've been doing that and no longer see the sticky plastic issue.
2023-2-18
HGDC84
Finland
That is clearly an issue for me. Makes them very weak eventually, and very disgusting to touch. WIsh they find a solution for this.
2023-2-18
PixelPro
Flight distance : 1205715 ft
they must have made them biodegradable or something.
2023-2-18
smbishop
Flight distance : 2479334 ft
DowntownRDB Posted at 2-18 03:22
I see this on my Pocket 2.  Thanks for the suggestion to use isopropyl.  I applied some, and it seemed to make a difference....
2023-2-18
DowntownRDB
smbishop Posted at 2-18 14:06
You're welcome Scott.  Hope you are having a great weekend.
2023-2-19
Mgozer
I hate this issue very much, since I've had it on several products.
As far as I know, every soft-touch plastic is affected by hydrolysis and eventually will end being sticky.
I have Osmo Action, Mavic Pro, Mavic 2 Zoom, Mavic Mini, Osmo Pocket and had Pocket 2, and none of them is affected by this issue.
2023-3-7
Mgozer
Regarding Isopropyl alcool, I use that to REMOVE the soft-touch layer from sticky affected objects.
2023-3-7
alloffroad
Best course of action is to use materials that do not present the issue, for instance, Zoom audio recorders have the same issue but they have a top customer service and replace each product and changed the material for future products.
2023-3-8
alloffroad
Mgozer Posted at 3-7 01:47
yes possible depending on the product but not what should need to be done, it's the company's fault for using materials not suited for the task.
2023-3-8
DowntownRDB
alloffroad Posted at 3-8 01:03
Can't argue with that great customer service.
2023-3-8
alloffroad
And by the way, I found a paste of a little water and baking soda works better than Isopropyl alcohol
2023-3-8
Mgozer
alloffroad Posted at 3-8 13:25
good to know, thanks
2023-3-9
HGDC84
Finland
Thanks for the tip, while my Pocket 2 does not (at least yet) show symptoms of this, it is good to know in case that does start to occur.
2023-3-10
