DJI Wanda
Hello, there. Thanks for your inquiry.
May we double confirm if you are talking about the DJI Mini 2 Two-Way Charging Hub in the DJI Mini 2 SE Fly More combo?
If so, we checked the information below:
The Output of the USB-A port on the DJI Mini 2 Two-Way Charging Hub:
Max Voltage: 5 V; Max Current: 2 A
The Osmo Action 3 can be directly charged by the power bank but the power bank’s output protocol must meet the camera’s input requirements.
you can charge the camera via the USB-C port. Action 3 supports PPS/PD fast charging protocol, and up to 23 W fast charge.
From the specification, you can use the DJI Mini 2 Two-Way Charging Hub to charge the Osmo Action 3 or other mobile devices. |
