Change language to English on RS3 Gimbal
4149 5 2023-2-20
Einherje
Norway
Hello, I have just bought a DJI RS3 gimbal. It has changed the language to chinese(?) before I even got it readily adjusted. How can I change it back to english?
2023-2-20
DJI Gamora
Hi, Einherje. Thank you for reaching out. On the DJI RS 3 touchscreen, please follow the steps below to change the language:
1. From the home page swipe down then select the gear icon (Settings).
2. Then scroll down to the very bottom and select the Globe icon (Language).
3. Then select English.
Hope this helps.
2023-2-20
Einherje
Norway
Hi, thank you for your reply. However it did not do the trick. I am still on only Chinese(?) language, and I cannot read the signs. I believe I have enclosed some pictures of my DJI screen, hope it will be readable.
Best regards.
2023-2-21
Paul Carpenter
Same issue here
2023-9-2
Einherje
Norway
Hello Paul, I do not remember what I did to solve the problem. And I can no longer find the mail I got from DJI, so I cannot send you a copy. However, I took pictures of the small screen on the DJI Ronin and sent the question to DJI, their answer solved the problem, ever since. Good luck. Jørn
2023-9-5
DJI Gamora
Hi, Paul. Thank you for reaching out. Have you tried following the procedure above?
2023-9-5
