djiuser_PTrEl1SpQTA7
Flight distance : 37316 ft
Yes, the controller is an RGN1. I use an iPad Air (3rd Generation) for the screen.
I observed my Air2S while it is completing a panorama 180. It was about 10 feet off the ground at the time. It rotates to take the images, and from the screen, everything looks normal. But when I pull the micro SD card from the drone and put it in my PC, neither the individual images for the panorama 180 are present, nor is the panorama itself.
The camera does record normal pictures and videos to the drone microSD card both in flight and on the ground.
I have had this drone since about October 2022 and I have used the panorama 180 feature many times. The problem developed after I upgraded the drone software. I had trouble updating the software in the normal way (through the RGN1) because the upgrade stalled. So I stopped it and ran the upgrade as a refresh using the DJI Assistant 2 on my PC. After the upgrade, the panorama images do not save to the micro SD card. I also upgraded the software on the RGN1.
George Hatfield
