DJI Gamora
djiuser_jcyIEOiqIbQd Posted at 2-26 02:41
Hello Gamora,
Thanks for your reply. I´ve just tested it on a different area (wide open field) and still I get maximum 33 mbps (image transmission). This happens like 1 meter away from the aircraft. I´ve updated both firmwares (goggles and drone) through DJI assistant and I get the same result. Also tried at 40ghz and same result....Considering this was tested in 3 different locations, all wide open fields, I don´t think the environment is affecting anything.
Hi, Ludo. Thank you for the update. DJI Avata doesn't have a factory reset feature. For factory reset on DJI FPV Goggles V2/2, you may go to Setting>About>Reset all. Please make sure to back up the files of the unit before restoring the factory settings.
If the issue persists, please provide us with the following details for further checking:
Here's how you can get the logs from the drone and goggles:
1) Connect the goggles/drone to the computer, and launch DJI Assistant 2 (Consumer Drones Series) which can be downloaded on this website: (https://www.dji.com/downloads/products/avata).
2) Click “DJI Goggles 2/V2 or DJI Avata” and “Log Export”, then select the required flight control data of the goggles. Click ""Save to local"", select the saved path, and wait until the download is complete.
Once the required information has been completed, kindly upload the file/s to Dropbox or Google Drive and provide us the shareable link via PM. Thank you for your cooperation and support. |
