DJI Tony
Hi, KrogFoto. Thanks for reaching out, and apologies for the inconvenience caused. We need to verify some details first. Just to confirm, the issue is the drone is set to take a photo, but it flies to the next location before you can take a picture, correct? If this is the case, kindly provide us with the following details for the investigation:
1. A video showing the setting of the waypoint mission;
2. App log and the tested time;
3. Flight controller and the tested time.
If you're using the DJI RC, you can export the logs through the DJI Assistant 2 (Consumer Drones Series).
Connect the drone and RC (one by one) using a USB cable, select "Log Export," and then save it. Kindly indicate the time of occurrence to locate the logs. Please send the following data via PM. We'll be waiting for your update. Have a nice day! |
