MS
Flight distance : 54469 ft
SPLflyer Posted at 2-28 06:12
Have you ever tried PanoramaStudio 3 Pro? There you can set that the position data of the individual images (incl. pitch and yaw!) are read out. So not only the 35 pano images are perfectly positioned, but also the vertical one automatically exactly in the zenith area. Furthermore, the exposure correction, respectively the exposure compensation with PS3P is much better than PTGui's (User Bussty recently switched from PTGui to PS3P after a long time because of this!) There is a trial version, give it a try.
Yes, I've got that software.
I haven't found any tutorials about how to use it properly. I've experimented with the Control Points on previous spheres, but they didn't seem to fix the joined images. So now I just use to to convert the flat pano into a spherical pano.
