Would turn sideways
865 2 2023-3-5
ieccpa
Flight distance : 200476 ft
Puerto Rico
After a firmware upgrade and using option 2 for the control stick, the right stick would not turn the drone sideway. Any suggestions. Thanks
2023-3-5
jmb63
Flight distance : 7009439 ft
There is an option in the app to "disable sideways flight"... I believe it is in the section with the obstacle avoidance setting. Probably got enabled during the update
2023-3-5
DJI Tony
Hi, ieccpa. Thanks for reaching out, and we're sorry to read about the difficulties you encountered. As suggested above, kindly double-check if the “Disable Sideways Flight” option has been enabled. You may check by going to Settings> Safety.
If this is toggled on, a sideways flight is unavailable in Normal mode. You may also check the Stick Mode set. If Mode 2 is set, the right stick is the tilt stick.
We will be waiting for your confirmation. Thank you, and have a nice day.
2023-3-5
