nOxxxx
Flight distance : 80646017 ft
Poland
The glass filter inside the gimbal optics has peeled off. This happens when the gimbal is hit, for example, by a branch. I damaged this filter. It broke into three pieces. The optical system itself is glued to a PCB with a CCD matrix. It can be peeled off when heated with hot air. Maybe try to set this filter in place and stick it. It will not be easy. Even if it is successful, unfortunately the image may be out of focus. It's worth a try though. Good luck. |
