RC Pro won't save waypoint route
2008 21 2023-3-7
GhostOfPlovdiv
Flight distance : 2164108 ft
So I went on a job today with my Mavic 3 cine + RC Pro. The idea was to save a waypoint route and then return several time over the next few months to go through the same waypoint route and shooting a video of a construction project. I can add the waypoints and the drone follows them precisely but when it's done there is no way to save the route to use next time I return to the contruction site. Tapping save and exit does nothing. The library is completely empty and there is no way to save it from there. According to to the app I have the latest firmware. Any hints to where the problem might be? This software failure botched me a nice paying job
2023-3-7
Mobilehomer
Flight distance : 18135846 ft
Maybe this will help.
2023-3-7
GhostOfPlovdiv
Mobilehomer Posted at 3-7 09:25
Maybe this will help. https://youtu.be/fA3nmHNG1XQ
I know how to do a waypoints video. The problem is I need to save the route so I can go several times in the span a few months and repeat exactly the same waypoints route to record the progress of the construction site. I am probably dealing with a BUG THAT NEEDS TO BE FIXED.
2023-3-7
Mobilehomer
Did you not pay attention to the saving portion?  Save it from the library, not from the save and exit prompt. DJI is aware of the bug.
2023-3-7
GhostOfPlovdiv
Mobilehomer Posted at 3-7 09:38
Yes. When I go to the library it is completely empty. It doesn't matter how many waypoints I have set before that.
2023-3-7
Mobilehomer
Have you tried setting waypoints while flying the route?
2023-3-7
GhostOfPlovdiv
Yes, I did that as well Also made 2 restarts of the rc and the drone.
2023-3-7
Mobilehomer
I have seen one workaround, using the satellite view instead of map view seems to work.
2023-3-7
GhostOfPlovdiv
Mobilehomer Posted at 3-7 11:18
So that will help me save the waypoints?
2023-3-7
Mobilehomer
GhostOfPlovdiv Posted at 3-7 11:25
I have read that here. Do a search for waypoints. It may turn up. It was in the past two weeks, I believe.
2023-3-7
DJI Gamora
Hi, GhostOfPlovdiv. Thank you for reaching out and we're sorry for the inconvenience. Just to clarify, after creating waypoints and clicking the button on the image below, don't you see any history routes?
If yes, Can you please provide us a video of the operation for further checking and please provide as well the firmware versions of the drone and RC, as well as the DJI Fly version? we will wait for your reply. Thank you.
2023-3-8
GhostOfPlovdiv
DJI Gamora Posted at 3-8 21:09
[view_image]
Hello and yes, after creating waypoints and tapping on the icon the list is completely empty. Tapping save and exit on the waypoints icon also does nothing.
Firmware is:
App version 1.9.0
Aircraft Firmware 01.00.1000
RC Firmware 03.01.1200
FlySafe Data 01.00.01.29
I will be able to do a video with the problem tomorrow.
2023-3-9
GhostOfPlovdiv
I just tested, as someone suggested, that I am able to add waypoints from the map itself. Can't add them the normal way sadly.
2023-3-9
frankymusik
Flight distance : 27904331 ft
GhostOfPlovdiv Posted at 3-9 03:03
Firmware is:
App version 1.9.0
App 1.9 0.  ?????
2023-3-9
GhostOfPlovdiv
Isn't that the latest version? When I tap check for updates it says I have the latest version installed. I am connected to the internet via WiFi.
2023-3-9
Mobilehomer
GhostOfPlovdiv Posted at 3-9 12:58
The latest Android version is 1.9.4, IOs is 1.9.5
2023-3-9
GhostOfPlovdiv
Mobilehomer Posted at 3-9 13:01
Okay this is interesting. How do I force the update?
2023-3-9
Mobilehomer
GhostOfPlovdiv Posted at 3-9 13:02
Try deleting and reinstalling
2023-3-9
DJI Gamora
Firmware is:
App version 1.9.0
Hi, GhostOfPlovdiv. Thank you for the details. The current version for DJI Fly is V 1.9.4. Kindly update it on your RC Pro by following this step: When the DJI RC Pro is connected to the Internet (connected with Wifi), enter the DJI Fly App, click [Profile] - [Settings] - [About] - [Check For Updates] to detect the latest version of the app and update it. Please keep us posted. Thank you.
2023-3-11
GhostOfPlovdiv
Everything works fine now! Case closed.
2023-3-15
DJI Paladin
Flight distance : 318 ft
GhostOfPlovdiv Posted at 3-15 08:48
Hi there. Sorry for the late response. We're glad that you already managed to isolate the issue that you experienced. Should you have other inquiries or concerns, please don't hesitate to reach us. Happy flying!
2023-4-11
G studio27
Flight distance : 2129199 ft
I have had similar issues, I set waypoints as a photo mission then I changed it to a video mission, 9start record at waypoint 1 and end record at last waypoint), It won't let me 'Save as" so it's just stuck...
Really poor navigation system for saving the waypoints.. Currently updating the firmware so hopefully this fixes the issue.
also lost an entire mission yesterday, created 99 waypoints, (max as aI understand..), tried to save it but lost the lot.. It's now showing as a 79 waypoint mission but they haven't saved properly so I'll have to go out and do it all over again..
Pretty random results from this DJI, not at all acceptable for pro use so far.
2023-9-7
