DJI Fly: Add buttons and info to the screen
1235 4 2023-3-11
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
There are functions that are needed for quick access, but they are only in the menu.
I would like to have such buttons on the main screen around its perimeter.
Buttons:
1) Update Home Point.
2) Subject Scanning -> White eye - off, Green eye - on.
Info:
1) Dron Temperature.
2) Battery temperature.
Maybe something else from other pilots.
2023-3-11
DJI Gamora
Hello there Drone.Hunter. Good day and thank you for giving out these information. I will forward these information to the designated DJI department for attention. All significant suggestions will be implemented after the evaluation of our relevant team. Thank you for your continued support.
2023-3-11
EvanOneal
It sounds like you would like to customize the main screen of your drone's control app to include quick access to certain functions and information. While the ability to customize the layout of the main screen may vary depending on the specific app and drone model you are using, here are some general tips that may help:      Check if your app allows for customization of the main screen layout. Some apps may have this feature built-in, while others may not.      If your app does allow for customization, look for the option to add buttons or widgets to the main screen. This may be found in the settings or customization menu.      If the specific functions you are looking for are not available as buttons or widgets, check if they can be assigned to a custom button or shortcut. This may also be found in the settings or customization menu.      If your app does not allow for customization, you may need to consider using a third-party app or alternative control method that does offer this feature.
2023-4-14
Johnnokomis
Flight distance : 13349895 ft
EvanOneal Posted at 4-14 11:20
Dude you are a total bot. I don't think it's possible to be more vague in a paragraph than you just did. Anybody who doesn't believe me just go look at EvanOneal's other posts. Total ChatGPT.
2023-4-14
afreekdusoet
Flight distance : 111476 ft
Barbados
Temperature info will be very useful to avoid loss of more drones.
2023-5-25
