supergeo.ca
Flight distance : 263537 ft
Rockbyter Posted at 3-19 12:29
It's the Pano shots i want, used to see a separate directory on the sdcard along with the DCIM folder containing all the images to stitch together but can't find them on the Mini 3 pro.
The following answer was copied from a reply from daflys:
Take off with the drone, select the pano you want the raw images for. Then press the three dots top right.
will have off, jpg, raw. select raW. After taking your pano you'll have a stitched jpg and a folder under Panorama named the same as that image containing all the raw files. |
