Screen Notification in Chinese language!
1038 27 2023-3-22
Hamad366
Flight distance : 583074 ft
Saudi Arabia
Hi
Today I was flying my drone and I touched the screen in way to see if it will zoom in using 2 fingers ( I know how to do using FN btw ) .. however, I noticed for the first I got a notification in Chinese! Why is that and how to get them in English .. i have never seen it before I own the drone for over a year
I don’t know if it’s related or not but recently I connected my drone to my laptop for dji assistant 2 .. just out of curious, I didn’t update or change anything just figuring it out .. is it possible something was changed after that ?
Here’s a screen shot
Thanks
2023-3-22
Hi there, we are sorry for the inconvenience. Could you please tell us the model of your drone and remote controller and the current DJI Fly version?
2023-3-22
Hamad366
Saudi Arabia
It’s Air 2s
The normal AC came with the drone
Latest version .. 1.9.5
I also tried to change the language from settings back and forth between default and English but didn’t help!
2023-3-23
Hamad366 Posted at 3-23 01:26
It’s Air 2s
Thanks for the information. We will forward this issue to the corresponding team for further confirmation.
2023-3-23
It’s Air 2s
Hi there, could you please reinstall the app or test with another mobile device to see if this issue also exists?
If the issue still exists after reinstalling the app, please provide us with the following information: Mobile phone model, system version, App version, App log, and operation screen recording.
2023-3-24
Hamad366
Saudi Arabia
I didn’t want to delete the app because I didn’t want to lose flight recored and logs .. how can I get them back if I do ?
and I’ll also try to install the app in another iPhone and see how it works ..
2023-3-24
DJI Wanda
Hamad366 Posted at 3-24 18:07
Hello, there. Do you mean Flight records, App Logs, or Flight Logs?
Flight records and App Logs can be exported out by connecting your phone to your PC.
You can also synchronize flight records in the DJI FLY APP so that they can be stored in the Cloud server.
Flight Logs are stored in the aircraft, you can connect to the PC and find it in the DJI Assistant 2. Reinstalling App will not affect Flight Logs.
2023-3-24
Hamad366
Saudi Arabia
DJI Wanda Posted at 3-24 19:18
Thank you that was helpful
2023-3-25
Hamad366
Saudi Arabia
DJI Mindy Posted at 3-24 03:35
I tried delete and reinstall the app, and also tried with another iPhone .. it didn’t help I still see the notification in Chinese .. I’m pretty sure it’s an issue with the app version
My device is iPhone 12 pro Max ios 15
The other device is iPhone 11 Pro ios 16
App is the latest version as I mentioned before 1.9.5
I don’t know how to send the logs .. are they still available after I deleted the app ? I didn’t read the message until now
2023-3-25
Hamad366
Saudi Arabia
Here’s a screen recording
https://streamable.com/nm2kce
2023-3-25
DJI Susan
Hamad366 Posted at 3-25 08:56
I tried delete and reinstall the app, and also tried with another iPhone .. it didn’t help I still see the notification in Chinese .. I’m pretty sure it’s an issue with the app version [view_image][view_image]
Thank you very much for your additional information. If the issue was reproduced after the reinstallation of the app, the log will be able to present the issue.
You can refer to this guide to export the log.
Thank you very much!
2023-3-25
Hamad366
Saudi Arabia
DJI Susan Posted at 3-25 22:28
I saw the same files in my iPhone using “ files app “
.. can I use this to upload instead of using iTunes which I don’t currently have, that log with 380kb is it enough ?
2023-3-26
Hamad366 Posted at 3-26 07:13
Sure you can do so if you can export the file folder through the method you mentioned. Since I am unable to open the link you posted above, can you please upload the file and the video to Google Drive or Dropbox and then send us the link here?
2023-3-27
Hamad366
Saudi Arabia
DJI Mindy Posted at 3-27 00:46
You can use the desktop version and copy  the links  then > paste to browser .. it’s not “clickable” I don’t know why
Here’s the logs:
https://we.tl/t-emEbqG6ONn
2023-3-27
Hamad366
Saudi Arabia
Google drive
https://drive.google.com/file/d/1axFqYXCT5udEzn6sgIKATVa0xy5VChtv/view?usp=drivesdk
2023-3-27
Thanks, the Google Drive link asks for permission, could you please take a look? Please also make sure the screen recording is also uploaded to Google Drive.
2023-3-28
Hamad366
Saudi Arabia
DJI Mindy Posted at 3-28 00:14
Sorry for the Inconvenience!
I changed the setting you should be able to watch the screen recored now with drive link
2023-3-28
Hamad366 Posted at 3-28 07:55
Thanks. We will forward the information to our engineer for further confirmation. Besides, we've released a new DJI Fly version, you can try to update the app to see if it helps.
2023-3-30
Hi there, may I ask if the issue is resolved? Did you update the app to the latest version v1.9.9? If the issue still exists, could you please provide us a screenshot to check the current aircraft and remote controller firmware version?
2023-3-30
Hamad366
Saudi Arabia
Hi
In aware there’s a new app update but I didn’t have time to check it, later today I’ll try it and see if it was resolved.
2023-3-31
Hamad366
Saudi Arabia
Hi
Unfortunately nothing has changed ..
2023-3-31
DJI Susan
Deeply sorry for the confusion caused. The engineers are aware of the Chinese message in the English language interface and will fix it in the future update of the DJI Fly app.
Just to double confirm, there is no issue zooming by using the fingers to zoom, right?
2023-3-31
Hamad366
Saudi Arabia
DJI Susan Posted at 3-31 19:13
Yes there is no issue using zoom with fingers or scroll in normal mode ..  it’s just the notification.
2023-4-1
DJI Wanda
Hamad366 Posted at 4-1 04:41
Got it. Thanks for your support and help.
2023-4-2
Hamad366
Saudi Arabia
Should I hear from you soon about this ? Ir it’s gonna be fixed silently ? I would love to know if this is a general issues or just with my account .. because it’s defiantly not a phone issue since I tried 2 iPhones. Thanks
2023-4-4
DJI Wanda
Hamad366 Posted at 4-4 12:09
This issue is only associated with language, not function. The Chinses text prompts that zooming is not supported under video mode. We will optimize the issue through App update.
2023-4-5
cptsteve24
Flight distance : 163701 ft
I have the same issue.  Has this been resolved?
2023-6-10
DJI Wanda
cptsteve24 Posted at 6-10 12:42
Hello, there. Sorry for the inconvenience. May we know did you try the latest version of the DJI FLY APP?  https://www.dji.com/downloads/djiapp/dji-fly
2023-6-11
