Climbing Altitude
1065 8 2023-3-26
Shawgod
Flight distance : 5173104 ft
I took my Air2S out flying the last couple days. Both days I spent a lot of time battling the drone from climbing on its own while going forward. And I am not talking a foot or two. I am talking about 100 ft in height over 1000 ft in distance. The wind was bad yesterday (approx. 25 mph 48 deg F) and wasn't so bad today (approx. 9 mph 49 deg F). A couple of days ago I did a sensor calibration with the camera and sensors. But that should not have done anything like this. So any help would be appreciated.
2023-3-26
Flyin Ryan 406
Flight distance : 2334925 ft
I had an issue where mine was turning to the left while pushing straight forward. I re-calibrated the controller and cleaned all sensors with a q tip and haven’t had the issue since. Hope that maybe helps.
2023-3-26
DJI Tony
Hi there. Thanks for notifying us about this concern. We're sorry you've experienced such issues. Here are some recommendations that may help the performance of the drone:
1. Calibrate the RC, aircraft IMU, and compass.
2. After the calibrations, please do a test flight in an environment with a strong GPS signal.
Kindly keep us updated. Thank you.
2023-3-28
Shawgod
When you say calibrate the RC how do you do that?
2023-3-29
JJB*
Flight distance : 12401030 ft
Hi
If you like share your flightlog for this issue, use > https://www.phantomhelp.com/LogViewer/Upload/
Post the uploaded link on here.
bad GPS does not make a drone increase its height.....
bad compass the same....
cheers
JJB
2023-3-29
Shawgod
JJB* Posted at 3-29 04:28
Hi
Using this log reporter How do I use this?
2023-3-29
Sean-bumble-bee
Flight distance : 15997 ft
Shawgod Posted at 3-29 04:01
It's an option in the app menus.   Try 3dot menu -> control then scroll down to "RC calibration".
2023-3-29
JJB*
Shawgod Posted at 3-29 05:17
Flightlog.txt is on your device, internal memory
What i do....connect the RC to my PC where it shows in the file explorer.
cheers
JJB
2023-3-29
DJI Tony
Hi there. Apologies for the late response. You may refer to the instructions shared by Sean-bumble-bee above. From the DJI Fly's Camera View, tap the three-dot menu, and it will route you to Settings.
Please let us know should you have other concerns.
2023-4-1
