djiuser_wSxBCyym5FAr
Croatia
I recently bought FPV combo (FPV drone, remote controller 2 and DJI goggles). Everything seemed fine when flying in normal and sport mode, but i noticed a problem when i switched to the manual mode, the drone's pitch and roll axis were too responsive even with overly tuned down rates and expo settings.
In the goggles remote controller calibration menu when i move the right stick (roll and picth axis) to about 10% or above on the controler it registers it as though i moved it to 100% in the goggles calibration menu.
Same thing happens when i connect the controller to the pc and use it with the simulator (Velocidrone), it reeds the input as 100% altho the stick is moved only 10% on the controller.
Controller is not damaged! I tried updating the firmware / setting it to the older version (on all three: drone, controller and goggles) nothing helped.
Does anyone know how to resolve this problem? Is the remote controller faulty or is it the firmware?
