After firmware, zoom control of 2470 lens
1578 10 2023-3-27
fansf61a54e7
South Korea
<After firmware, zoom control of 2470 lens>
I am using an R4D camera with a Sony lens (27-70GM2) attached.
Using the focus motor, the zoom of the 2470 lens was controlled.
and,
Recently I went through R4D Firmware: v01.04.0300
After firmware, zoom control on 2470GM2 does not work.
(Of course, I set the function of the right hand grip button to 'zoom')
After firmware, the Sony E18-105 lens can control the zoom using the right handgrip without a focus motor.
But my main lens is the 2470GM2.
Is there any other way than downgrade?
Thank you for continuing to do the R4D firmware.
But wait for more sophisticated firmware.
2023-3-27
DJI Wanda
Hello, there. Sorry for the inconvenience. May we know did you upgrade the firmware of the E-mount?
https://forum.dji.com/forum.php? ... &extra=page%3D1
2023-3-28
fansf61a54e7
South Korea
DJI Wanda Posted at 3-28 02:35
https://forum.dji.com/forum.php?mod=viewthread&tid=257489&extra=page%3D1
Yes, of course I updated the E-mount unit's firmware.
2023-3-28
fansf61a54e7
South Korea
sorry. It seems that the firmware of the e-mount unit did not work properly.
Tried the firmware of the e-mount unit again, and after the firmware is completed, the zoom control is normal.
No problem.
But there is another problem.
The focus motor is not firmwared.
I replaced the USB cable and rebooted the MacBook and R4D several times, but it fails at 99% each time.
At the bottom of the DJI Assistant v2.16 screen, (1f05080403) is displayed in red letters, but I am not sure if this is an error code.
2023-3-28
DJI Wanda
fansf61a54e7 Posted at 3-28 19:33
Sorry for the late response. We are asking for the reason. Will update here after we get the answer.
2023-3-29
DJI Wanda
We receive the response.
If you only have the DJI Ronin 4D+DJI Zenmuse X9 focus motor, please do not enter the upgrade page of the "Focus Motor" to upgrade the firmware version V00.03.04.64, and a prompt of upgrade failure will appear.
The version is for DJI Ronin 4D with Flex + DJI RS follow focus motor (2022) to upgrade the DJI RS follow focus motor (2022);
2023-3-30
fansf61a54e7
South Korea
DJI Wanda Posted at 3-30 05:15
If I don't have a Ronin Flex, there seems to be no need to update the firmware (V00.03.04.64).
Thank you for your kind reply.
2023-3-30
DJI Wanda
fansf61a54e7 Posted at 3-30 20:10
You are most welcome.
2023-4-2
Chapeaublanc
Flight distance : 25794 ft
Hi every body, I'm experiencing the same issue and error (1f05080403) but I have the FLEX and I need it to use with manual lenses (SIRUI anamorphics).
After a lot of different tries, I could not upgrade the Focus Motor, and No it don't work with the Flex (it work properly when attached directly to the main body).
2023-12-18
Chapeaublanc
Do you have any advices to upgrade the Focus Motor differently?
2023-12-18
Chapeaublanc
Sorry for the "too" quick response. I find how to solve it.
I upgraded the "Ronin RS Focus Motor" with the flex correctly, and After rebooting the camera (without the flex and the Ronin RS Focus Motor) I had the "inconsistent firmware message". I think it downgraded the 4D focus motor, who now work properly with or without the Flex.
My both (4D and RS) motors work properly now.
2023-12-18
