Camera Lens Actual Focal Length
3797 8 2023-3-30
Flight_Cacher
Flight distance : 517011 ft
I am trying to track down the actual focal length for the Mini 3 and Mini 3 Pro, not the "35 mm equivalent".
Guessing it is around 4-6 mm??
Is it the same on the Mini 3 and Mini 3 Pro?
If someone could also verify the image width and height. I have found 4032x3024?
It also appears the Sensor width is 10 mm, and height is 7.5 mm?
Thanks.
2023-3-30
DAFlys
From the spec.
The lens has a focal length of 24mm (full-frame equivalent, 82.1° FOV)
2023-3-30
Flight_Cacher
DAFlys Posted at 3-30 23:51
From the spec.
Thanks for the response, but that is the 35mm equivalent. I wanted the actual which I believe is 6.72 mm.
2023-3-31
DAFlys
Flight_Cacher Posted at 3-31 07:38
The only spec Ive seen is that it's a 6.7mm lens diameter.
2023-4-1
supergeo.ca
Flight distance : 263537 ft
6.72mm is the spec that is shown on my Mini 3 Pro photos when checked on my pixel 6 phone.
2023-4-1
Flight_Cacher
Thanks, that confirms what I found.
2023-4-1
djiuser_kzaqwJdDCKay
Hi all
I am looking to use my DJI Mini 3 Pro for some Ground Sample Distance work.
I am currently trying to work out the values for:
1. Sensor Width/Height (mm) = width of the drone camera's sensor;
I believe to be 9.65 mm (W) × 4.24 mm (H)
2. Image Width/Height (pixels) = Number of pixels in the drone camera's image resolution;
I believe to be for images 8064 x 6048 based on the settings of 4:3/48 MP, and for videos 3840 x 2160 based on the settings of 4K/24/25/30/48/50/60fps
3.  True Focal Length (mm) = The true focal length of the drone's camera.
Would any of you be able to confirm the values I have obtained and also explain how you came to the conclusion that the DJI Mini 3 Pro has a true focal length of 6.72 mm?
Many thanks!
1-3 03:48
Labroides
Flight distance : 9991457 ft
djiuser_kzaqwJdDCKay Posted at 1-3 03:48
Hi all
Look at the image metadata from an image file from the camera and it will show you the actual focal length of the lens.
1-3 05:35
cyan
Ban Posts
Flight distance : 202326 ft
1-6 22:07
