Sven.Olivier
Flight distance : 4867106 ft
South Africa
Good day All
Would just like to find out if anybody has had an issuse while in flight that the PC Plus detects that the battery is either disconnecting or a signal loss which then causes the percentage of the battery to jump between 82% and 6% then back and forth.
when i landed the aircraft i checked that the batteriers were seated correctly and the battery clips were ingagde correctly as well.
Should i be worried and send the unit back to the supplier for diagnostics testing or replacement?
Regards
Sven
Battery
Battery 1
