Ranjan
India
To access the flight records that you have uploaded to the cloud from your DJI Mini 3 Pro with DJI RC controller, you can follow these steps:
Open the DJI Fly app on your mobile device.
Make sure that you are logged in with the same DJI account that you used to upload the flight records to the cloud.
Tap on the three horizontal lines in the upper left-hand corner of the screen to access the main menu.
Tap on "Flight Records" from the list of options.
You should see a list of all the flight records that are associated with your DJI account.
To view the details of a specific flight, tap on the flight record from the list.
You can view a summary of the flight details, including the flight time, distance, and maximum altitude. You can also view the flight path on a map, as well as other flight data such as speed and battery level.
If you have uploaded photos or videos to the cloud, you can also access them from the flight record details page by tapping on the "Album" tab.
Note that you must have enabled flight data synchronization in the DJI Fly app in order for your flight records to be uploaded to the cloud. If you have not done so, you can enable this feature by going to the "Settings" menu in the app and selecting "Advanced Settings" > "Data Sync" > "Flight Records." |
