Goggles 2 OSD to wide
3253 25 2023-4-6
SoNicK64
Flight distance : 111703 ft
Hi All,
I'm Niek from the Netherlands and have an awesome AVATA with Goggles 2 and controller 2.
Really happy with my purchase and the AVATA performs great.
But, just as many others i experience a lot of blurryness in the corners of the Goggles 2, the image is cristal clear and sharp but in the corners i can't read important information about a battery or flight info.
Can't DJI make the OSD less wide so important info stayes in focus, think there is room enough to do so. Don't think either it will be that difficult to programm it.
Would even be more great if you could change the looks of the OSD the way you like it.
I have made a photoshop comparison how it could look like.
Regards Niek
Goggles 2 OSD
Goggles 2 OSD
2023-4-6
Hi there, we will forward your feedback to the corresponding team for further confirmation.
2023-4-7
SoNicK64
DJI Mindy Posted at 4-7 02:29
Thank you Mindy, for the fast response.
Hope to here the follow up, and if my question is realizable.
Regards, Niek
2023-4-7
SoNicK64 Posted at 4-7 03:24
Hi, may I ask if the photo is a screenshot from the Goggles 2? Please adjust the goggles’ interpupillary distance to see if the issue still exists. If so, please provide us with a screen recording for further confirmation.
2023-4-8
SoNicK64
Hi Mindy,
the Photo is from the recording and photoshopped by as an example.
The recordings are fine and sharp from edge to edge and cristal clear in the corners.
It's what I see in the goggles when looking trough them. I tried everything with pupillary distance and dioptry to get them right, but when I see the corners sharp the center is blurry and vise versa.
I gave the goggles to several people and let them change the pupillary distance and dioptry to match their eyesight but all experience the same, blurry corners.
I can life with the fact that the corners are blurry, but that i can't read important flight info is bothering me.
Just keep the flight info out of the corners and more in the center will make a lot of users happy and more safe.
Regards, Niek
2023-4-8
SoNicK64 Posted at 4-8 03:01
Hi Mindy,
Thanks for the confirmation. Could you please follow the steps below to record a camera view for our further check?
1. Switch on the "Camera View Recording" button on the DJI Goggles 2, 「the path is Settings>Camera>Advanced Camera Settings>Camera View Recording」.
2. Swipe down from the top of the touch panel to enter the shortcut menu, then start recording. DJI Goggles 2 will record the on-screen display.
2023-4-9
SoNicK64
Hi Mindy,
I think you don't understand what I mean.
Goggles are fine, recordings are fine, OSD texts and info are fine. It's my eyes that can't see sharp in the corners. DJI can't help with my vision, but if DJI could make de OSD info more to the center, then I can read the OSD, because it's not in the corners anymore.
Did you send my first message with the image to the corresponding team? They probably know what i mean, and this simple OSD fix would please many people.
Regards, Niek
2023-4-9
SoNicK64 Posted at 4-9 01:53
Hi Mindy,
Since you mentioned that this picture is a screenshot of Goggles 2, generally, the screen recording will show the same as the screenshot. But you mentioned the recording is fine, therefore we want to have a screen recording for further confirmation. May I ask do you mean the screenshot and screen recording is different? Do you mean the screenshot shows blurry OSD, but the screen recording shows clear OSD?
2023-4-9
SoNicK64
Hi Mindy,
never said I made a screenshot. I made a photoshop image myself to show you what I mean with the blurry corners. It's an example of how I see my screen while looking trough the goggles and how it could look like when the OSD info is not in the corners. I will say again, the goggles are fine, the recordings are fine. It's the view trough the lenses of the goggles that is blurred in the corners.
You could google this issue and find many people having this problem.
Doesn't make sense to make a recording with the goggles, because they are fine.
2023-4-9
tompajo
Sweden
Niek, I have the exact same problem. It seems like the girl from dji haven't used the googles.
2023-4-11
DJI Wanda
SoNicK64 Posted at 4-9 03:06
Hi Mindy,
Hello, there. Sorry for the inconvenience. We consulted your issue with our engineers. Please check whether the Audience mode or Focus mode is enabled. If not, since your issue can not be further determined remotely, we recommend you send it back for further diagnosis.
Here is the link: https://www.dji.com/support/repair?from=store_homepage
2023-4-11
SoNicK64
DJI Wanda Posted at 4-11 22:54
Sending it back isn't gonna help, goggles are fine.
Internet and this forum is full with customers complaining about blurry corners and bad readability of OSD info in the left and right corners, it's the design of the goggles with the wide screen that makes it impossible for us to get the corners clear in focus.
That the corners are blurry when we look trough the goggles isn't that much of an issue, our focus in flight will always be in the center anyway.
BUT, that we can't read the important flight info in those corners is bothering us.
My question was, if it would be possible (think it is) to keep the flight info out of those blurry corners and project it more in the bottom center.
I'm getting the feeling that you don't want to understand what we are experiencing here.
Put the goggles 2 on (you work at DJI right?) and see for yourself what we mean.
Still think this isn't communicated with your engineers, because they are probably already familiar with this issue. (i'm not the only one complaining).
I read that people send there Goggles back because of this issue while it could be fixed.
DJI would have more satisfied customers and make more revenue.
Regards,
Niek
2023-4-12
DJI Wanda
SoNicK64 Posted at 4-12 04:43
First, the answer to your question whether you can adjust the OSD position on DJI Goggles 2 is no,
Second, to your question about why we insist you send the DJI Goggles 2 back, the reason is that:
1.  DJI Mindy and I went through the troubleshooting steps with you. However, the information you provided is not enough for us.
2. Based on the information, we consulted with our engineers and of course, we could not reproduce the issue from our side so that we mentioned your issue can not be further verified remotely.
3. As you said, the recordings are fine and the DJI Goggles 2 are fine but the vision in your eyes looks exactly like the photoshopped picture. We do not know how to check the problem you said even though we really want to help you.
Moreover, we would like to know whether the Audience mode or Focus mode is enabled. Would you please tell us your feedback?
We appreciate your understanding and support.
2023-4-12
Robino
Slovakia
I admire your patience. Those Dji girls are completely gone, they don't understand anything. It is like a bad joke to read their words. They simply don't have the experience and never had a goggles 2 on their faces. Otherwise they would know...
Off topic: They tried to persude me that my O3 air unit is faulty because I had "Goggles battery overheated" warning shown on the screen. I said them the O3 air unit has no battery. They send me wiring diagram to prove there is an input voltage. I said, yes there is voltage coming from a BEC but O3 air unit has no chance to know what the BEC temperature is. There is no sensor on it. They couldn't understand it. I was amazed.
I am making my own custom face mask. I found out it could help to see the screen much clearer. https://forum.dji.com/forum.php? ... 5&page=1#pid3020493
2023-4-13
DJI Wanda
Robino Posted at 4-13 02:17
Off topic: They tried to persude me that my O3 air unit is faulty because I had "Goggles battery overheated" warning shown on the screen. I said them the O3 air unit has no battery. They send me witing diagram to prove there is an input voltage. I said, yes there is voltage coming from a BEC but O3 air unit has no chance to know what the BEC temperature is. There is no sensor on it. They couldn't understand it. I was amazed.
Hi, Robino. We apologize for any inconvenience caused. About your issue, we will check it first.
Hope you can understand that we take each issue seriously and will treat it case by case.
If you have any questions about the issue you encountered. Please let me know.
2023-4-13
Robino
Slovakia
DJI Wanda Posted at 4-13 04:42
Hi Wanda, I do not need anything.
2023-4-13
DJI Wanda
Robino Posted at 4-13 05:15
Sorry for the late response. We saw that you had questions about the response we gave to you before.
We will consult with our engineers again. Please feel free to talk if you have any questions.
2023-4-13
VladimirTalijan
Flight distance : 75640 ft
LOL I just bought the Goggles 2 and I have exactly the same problem with blurry edges. I've always thought of DJI as an out of box thinking company which is very rare for a Chinese company, but their customer service is like a 6 month old company selling $5 items
I'm not even sure that replacing it with Googles V2 is the solution so I will be returning everything back until they make a proper set of goggles.
2023-11-19
DJI Susan
VladimirTalijan Posted at 11-19 17:12
Hi there, I am sorry for any inconvenience caused. May I double confirm if you are having the exact experience as the OP had?
Please try to adjust the goggles’ interpupillary distance and check if it is related. If it is possible, please also try to compare it with others in the local retail store. If it has a great difference, please take a picture and provide it to me for further confirmation.
I will also forward your feedback to the engineers for their attention if it is the same with other Goggles after you check at the local retail store. Thank you very much.
2023-11-20
Christian Sterneborn
Sweden
I also got the same issue. A new osd layout is the best option i think. In my case its the facemask that is wrong fit. The left down corner is blurry and the rest is sharp. Its little strange that dji havent notice this because sounds like many people have the same problem with this...
2023-11-29
Kstar
I just want to confirm that I am yet another user with the same exact issue and complaint with these DJI googles 2 having blurry edges.
Support please try on a pair of these googles and try adjusting the IPD just right so that you see no blurry edges in either eye. If your shift the IPD wide or narrow there seems to always be a blurry edge.
A simple fix for this goggle would have been to make the lenses slightly larger to allow for some variability between users faces. Not every eye sits as deep in the socket as another.
Sure we have IPD.. even a -8, +2 corrective adjustment available. Yet we still have this issue that multiple customers complained about now, on multiple threads. This issue is simply here because there is no expected variability in the distance of the eye to the lens in the google. This would have most easily been evaded by using the same wider lenses in the goggles V2 instead of a perfectly round lens... Or else making it just larger in general if you guys wanted these lenses to be different and round.
I switched to digital from analog. I was even considering the new DJI Avata 2. My disappointment with this failure in design, the lack of support, the lack of understanding of this complaint, are a strong detour in considering another DJI product again.
4-24 21:27
DJI Wanda
Kstar Posted at 4-24 21:27
Hello, there. Thank you for your feedback.
It is difficult to determine the issue remotely of the view in the Goggles.
We suggest users refer to the Suggestions of DJI Susan at 22#
At the same time, we will forward your feedback to our related departments.
4-25 01:19
Kstar
The same issue as described by multiple users on this thread. And on other threads. Are you seriously suggesting that I take my googles 2 to a DJI store and ask to compare how bad they are with other googles? Is this a ploy to get users working with a sales rep to sell more bad DJI products instead of addressing a defect that you sold. When you sell defective gear and there are multiple users who complain about it. Then a company is expected to make this right. The evidence is apparent when comparing the DJI googles 2 with the googles 3.. Now there is no foam so that your eye can sit closer to the lens.... Exactly as I described. The distance to the lens from a users eye... Yet you guys want to do a back and fourth with me on it here. Since the DJI googles 2 are obviously flawed. You can see that it was corrected in the DJI goggles 3. The googles two could have been fixed buy offering some sort of kit to accomplish this since the mold is basically the same. Yet the strap and the face foam are different. This shows that you guys do know. Yet you choose to do nothing for your customers which you have sold a defective product to.
4-25 11:36
Kstar
After my last post here I spent an hour or so carefully cutting out as much of the forehead foam as possible from the original Goggles 2 facemask. Similar to the new design of the facemask on the googles 3. interestingly enough now IPD along with focus is able to get a decent view of the entire screen without having some blurry edge.
I strongly recommend that you work better on your customer relations when users are reporting issues with your devices. It is a known fact in the FPV drone community that DJI support is not helpful to their customers concerns like this. However we can all see that changes are made in the Goggles 3.
So which is it? Are the Goggles 2 designed badly? And this blurry edges are a known issue? Leading to the development of a Goggles 3?
Or else are we all crazy that complained about this? We need to take our Goggles into a store.. Or send them back for a repair and evaluation?
We shouldn't have to spend extra time, effort, or money. To fix your products so they work properly. You guys could have done many things to make this right to your customers and you have refused.
4-25 16:55
SoNicK64
I replaced the faceplate with a thinner one (aftermarket) and it is more comfortable and image is better cos my eyes are closer to the lenses.
It's better but could be even better if the osd info would be more in the center and not on the outer edges.
4-25 23:56
DJI Wanda
Kstar Posted at 4-25 16:55
May we confirm the issue you said was resolved after you redesigned the foam pad on the DJI Goggles 2?
We will forward your feedback to our R&D departments. Sorry for the inconvenience again.
yesterday 05:42
