The Saint
Flight distance : 5902228 ft
it's just my opinion but i believe you are misusing the setting. what are you going to do when the rules change and we are allowed to fly at 500ft, do we demand a sw update? right now the limit is 400 feet, does dji remove all settings higher than 400 feet because of the rules? no? aha, now you want to reference AGL....can't have it both ways.
laanc is mostly indicated in predictable increments such as 100 or 150 feet. of course, you'll never match those increments precisely in the settings due to metric conversion. how do you manage with the current settings? you don't....because when you are flying under laanc, you manage your max height with the rc as the pic like you should.
dji sees it the way i see it: it doesn't matter if you set it 393 or 410, either way you are not breaking any rules. even if you live in flat as a pancake nebraska, there's a good chance you are somewhere over or under the limit and as far as we've seen from the faa, that's ok. at least for me, the intended use of the setting is to keep your drone from launching into outer space especially an fpv drone where you are climbing and diving mountains and you actually find yourself reaching the 5, 6, 700 marks.
i don't know how this works but isn't this max setting also sent/stored to the drone so when/if there is a flyaway that disconnects and rth is not triggered, the drone is less likely to drift off into the wind up and away towards manned aircraft? i dunno.
eta: the autel has a box where you enter the number and sliders and it's a pain because you not only have to deal with a cursor but you also have to use the save/return key to take the entry. there's no way to accurately slide the slider when you have a range from 0 - 2000 on a 2-inch path. try changing 150 to 250 at the bottom end, it's ridiculous so you almost always accept getting close.
