dronethemoment
Flight distance : 9021293 ft
Alexis Images Posted at 4-10 07:07
Hi again
Based on my understanding of what you are suggesting (which I think is very clever!) what about:
a) Short waypoint route from a point x (near my starting point) to my starting point. When I get to the end I think the drone pauses anyway
That's about the only way you're going to get near enough to your original starting point. I use a very short hyperlapse waypoint on the Mavic 3 in video mode, then switch over to the Hyperlapse and begin. I realize video waypoints is not an option in the Mini 3 Pro, so a quick hyperlapse to your starting point would be the way.
They would do the Mini 3 Pro great justice by allowing POI in the hyperlapse waypoint so that you could somewhat accurately repeat the mission, but of course, they give you the minimum for the amount of money you spend.
I'm also waiting for the day when you can PIN the map and that PIN is selectable and you can fly to it. The only way is a waypoint, as the PIN doesn't do anything and can only manually navigate to it. Once you restart the controller, the pin is lost.
The other solution to this is wait for the SDK and use 3rd part like mentioned. Litchi is one of my favorites back on the Mavic Pro series. |
