autofocus not engaging mid flight
1301 35 4-11 05:12
tazzt0ne
Flight distance : 1218235 ft
Switzerland
so i wanna shoot something up close (especially nice with the f1.7 bokeh) and then fly away and reveal the surroundings with a speed ramp effect in between like i did here:
similar to dronie quick shot.
but unfortunately the focus will never change from the one aquired at the start of the recording resulting in a big blurry mess.
so DJI: will this be fixed? (i am on latest FW btw)
according to a reddit user this same issue is not present in mini 3 (non pro) https://www.reddit.com/r/DJIMini ... ini_3_pro/?sort=new
4-11 05:12
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We will coordinate this to our designated team for attention. Thank you for your understanding and support.
4-11 21:22
tazzt0ne
Switzerland
DJI Paladin Posted at 4-11 21:22
here is another example where the AF was only engaged after the drone came to a stop
4-12 00:21
Ranjan
India
tazzt0ne Posted at 4-12 00:21
https://www.youtube.com/watch?v=Lbf2whK-TRk
Looking at the video I think you need to go slow so AF have enough time to detect where it needs to focus. I never start recording from the ground so cant confirm this but will test this weekend how it deals with AF
4-12 00:48
tazzt0ne
Switzerland
AF will not engage no matter how slow u fly backwards. only engages AF after drone stops moving. i get why DJI does that: less AF wobble during recording.
maybe we need some AFS/AFC modes toggle (AFS = how it is currently) and AFC = continuously adjust focus mid flight!
4-12 01:10
Burt37
Flight distance : 4009 ft
tazzt0ne Posted at 4-12 01:10
AF will not engage no matter how slow u fly backwards. only engages AF after drone stops flying. i get why DJI does that: less AF wobble during recording.
I'm not sure if I'm giving you the right answer here but I was doing the same mistake think that AF meant Autofocus as in constantly on focus... I was wrong the Autofocus is only on when the picture of the two little mountain are on (infinity)...
Have a look at this video to better understand what I mean. I hope that is what you were asking...
4-12 01:50
tazzt0ne
Switzerland
Burt37 Posted at 4-12 01:50
you wrote: the Autofocus is only on when the picture of the two little mountain are on (infinity)
this is completely wrong. this is MANUAL focus mode, not autofocus.
4-12 01:55
Burt37
tazzt0ne Posted at 4-12 01:55
Autofocus only apply when you touch the screen... Have a look at the video...
4-12 01:57
tazzt0ne
Switzerland
Burt37 Posted at 4-12 01:57
no it will also autofocus when u stop moving
4-12 01:58
Burt37
tazzt0ne Posted at 4-12 01:58
Mine doesn't. When in AF it only focus on what I touch on the screen...
4-12 02:01
Tuxtard
Flight distance : 9258602 ft
Serbia
Use manual focus and move the slider to the top until landscape icon appears.
4-12 02:07
Burt37
Tuxtard Posted at 4-12 02:07
Yes, I have already told him that... And it is also in the video...
4-12 02:08
tazzt0ne
Switzerland
then the grave / shoes or whatever subject is close in the beginning of the shots would be out of focus. since with f1.7 aperture and the sensor size of m3p not everything (far and close) can be in focus at all times. optic principles
4-12 02:11
DJI Wanda
Hello, there. Sorry for the inconvenience. May we double confirm that Autofocus works properly except for the case you mentioned, fly backward?
4-12 02:41
tazzt0ne
Switzerland
DJI Wanda Posted at 4-12 02:41
hey thanks for following up.
the problem is: AF won't CONTINUOUSLY adjust focus while flying away farther.
it's NOT because of direction of flight (backwards forwards or sidewards). rather it comes from the fact that the AF will stay locked on whatever was in focus at the beginning of the recording.
4-12 02:46
Burt37
I'm really curious to see what the DJI team will reply to this...
4-12 03:39
DJI Wanda
tazzt0ne Posted at 4-12 02:46
Thanks for your reply. We consulted with our engineers.
Here is the response:
During the aircraft ascends to a low altitude, the objects are continuously changing. This unstable condition conveys information to focus and impacts focus accuracy at last.
Therefore, AFC is unable to be triggered in the midst of moving/flying until the aircraft stays stable.
Thank you for your feedback. We will forward it to our related department for evaluation and optimization.
4-13 01:26
tazzt0ne
Switzerland
DJI Wanda Posted at 4-13 01:26
i see how the engineers chose to play safe here by not activating AF during flight. but maybe an optional AFC mode for smooth adjusting focus while moving would be feasible.
until then i will try manual focus pulling.
4-13 01:55
DJI Wanda
tazzt0ne Posted at 4-13 01:55
Thanks for your advice. I will transfer it to them together.
4-13 02:44
Burt37
4-13 03:10
tazzt0ne
Switzerland
same issue in this video:
at 3:39 it refocuses after drone stopped moving. and he 'didn't tap to focus'
reading comments it seems many people are having these focus issues. they take off thinking AF will take care of everything, yet it is not actually focusing automatically if the drone is moving
4-13 07:33
trainee
Flight distance : 31759 ft
tazzt0ne Posted at 4-13 07:33
Whatever he said, it looks to me as though there was a focus screen tap at 3:38, judging by the video glitch.
4-13 09:11
tazzt0ne
Switzerland
trainee Posted at 4-13 09:11
this is not a video glitch but the AF actually autofocusing coz the drone came to a stop.
4-13 09:49
trainee
tazzt0ne Posted at 4-13 09:49
It's certainly a video glitch, whatever has caused it. And if that's what happens every time autofocus kicks in then AF looks like a surefire way to ruin any flight video.
4-13 15:19
Drone.Hunter
Flight distance : 877123 ft
Kazakhstan
QuickShot - Rocket. Focus...
4-13 17:49
tazzt0ne
Switzerland
trainee Posted at 4-13 15:19
fine call it a "glitch" then. it's nothing but the lens focusing tho. and yes such autofocus can ruin a video, that's why DJI choses to engage it so sparely. resulting in many people having out of focus video however
4-13 21:54
trainee
tazzt0ne Posted at 4-13 21:54
fine call it a "glitch" then. it's nothing but the lens focusing tho. and yes auch autofocus can ruin a video, that's why DJI choses to engage it so sparely. resulting in many people having our of focus video however
Does AF work the same way on other DJI drones? How about other manufacturers' drones? My only other drone was the first Autel Evo which never had a focus issue in the two years I flew it.
4-13 23:04
tazzt0ne
Switzerland
trainee Posted at 4-13 23:04
depends on the lens aperture (f1.7 on mini3pro) and the sensor size. since those 2 factors determine 'depth of field' and the need to focus or not. eg mini2 has a smaller sensor and f2.8 (afaik) so they could leave out focusing mechansim alltogether. effectively many chose to go that route too by leaving manual focus on 'infinity'  with their mini3pro. close subjects will be out of focus in each case, less so on mini2 tho
4-14 00:11
trainee
tazzt0ne Posted at 4-14 00:11
How close will he M3P focus in both modes? In MF infinity mode I think I lose focus at around 6ft.
4-14 01:36
tazzt0ne
Switzerland
trainee Posted at 4-14 01:36
it's subjective anyway: depends at what point u find the image to be soft enough to call it "out of focus". according to dji specs: minimum focus distance is 3.3′ / 1 m.
in both AF and MF u should be able to focus from 1m to infinity.
4-14 01:38
tazzt0ne
Switzerland
btw i just tested today. minimum focus distance is much less than 1m
4-14 23:11
trainee
tazzt0ne Posted at 4-14 23:11
Thank you! I can see that focus peaking is reporting focus but I would need to see the higher res image to confirm. And you would think that DJI would shout about it if you can focus at 6 inches…
4-15 00:46
tazzt0ne
Switzerland
trainee Posted at 4-15 00:46
high enough resolution for you?
4-15 02:18
trainee
tazzt0ne Posted at 4-15 02:18
[view_image]
Ha!… that works. Thanks.
4-15 02:29
tazzt0ne
Switzerland
this is a still from 4k video (cropped) while the drone was scarily hovering in front of me with obstacle avoidance turned off.
4-15 02:30
tazzt0ne
Switzerland
Drone.Hunter Posted at 4-13 17:49
https://www.youtube.com/watch?v=BgQkTllBikI
i tried quickshot dronie yesterday. it does not have AF. rather it has fixed focus on far away things, so if u start very closely to a subject, you can see it is out of focus.
4-15 03:46
