Avata - Rocksteady not working at all
853 7 2023-4-11
AngryConsumerMa
Flight distance : 216916 ft
Just got my Avata, flew it on a little bit of a windy day, discovered that if the wind comes from the side, the horizon is at an angle. Camera is generally shaky, totally looks like what is recorded in the goggles.
Are there camera settings that will cause Rocksteady to not work? Such as 4K/60, etc?
Any assistance in this is greatly appreciated.
2023-4-11
DJI Wanda
Hello, there. For the issue you mentioned, can we have a video to have a look?
2023-4-11
AngryConsumerMa
Good morning,
I'll have to post the video somewhere to show what it's doing.
Question - what frame rates does the Avata support for Rocksteady? I can't find any documentation anywhere.
2023-4-12
DJI Wanda
AngryConsumerMa Posted at 4-12 03:39
Good morning,
Thank you so much.
For your questions, may we know the specification you need is under Standard, Wide-Angle, or Super Wide Angle? We will search for the information for you.
2023-4-12
AngryConsumerMa
Hello again,
As I had stated earlier, I'm new to this drone and FPV in general. I was hoping that there would be a chart somewhere that showed what features work with what settings.
Like something that shows:
Standard - Rocksteady & Horizonsteady only work with the following frame-rates, etc.
Wide-Angle - Rocksteady & Horizonsteady only work with the following frame-rates, etc
Super Wide Angle - Rocksteady & Horizonsteady only work with the following frame-rates, etc
I looked around the manual for the drone, and couldn't find anything that clarified that.
Again, thanks for your help with this!
P
2023-4-12
DJI Wanda
AngryConsumerMa Posted at 4-12 04:48
Hello again,
Sorry for the late response. Here are the information:
Rocksteady              1080p(16:9)                            1080p(4:3)                2.7k(16:9)                       2.7K(4:3)                       4k(16:9)
Standard                  50/60/100/120fps        50/60/100/120fps           50/60/100/120fps           50/60/100/120fps          50/60fps
Wide-Angle              50/60/100/120fps        50/60/100/120fps           50/60/100/120fps           50/60/100/120fps          50/60fps
Super Wide Angle   50/60fps                        50/60fps                             50/60fps                          50/60fps                          50/60fps
Horizonsteady only supports in Standard, and can not record in 100 and 120fps.
May we know if you uploaded the video? Can we have a look?
2023-4-12
AngryConsumerMa
That would explain why the stabilization wasn't working!
I'll try the new settings, and report back.
Thanks for the help!!!
P
2023-4-15
DJI Wanda
AngryConsumerMa Posted at 4-15 08:20
You are most welcome. Please tell us your feedback.
2023-4-15
