Labroides
Flight distance : 9991457 ft
During RTH does the drone:
1) go up to the set RTH altitude, then follow a straight line to the home point before decending?
Or
2) does it go up to the set height , then return along the same ground flight path as it followed going out?
The answer is ... that depends.
If you initiate RTH by pushing the RTH button, the drone will take a straight line path directly from where it is.
If the drone initiates RTH because of lost signal (Failsafe RTH), it will initially retrace its path from before signal was lost.
This usually solves the lost signal issue if signal was lost because you flew behind an obstacle.
For more information on Failsafe RTH and other RTH scenarios, see page 15-16 here:
https://dl.djicdn.com/downloads/DJI_Mini_3/UM/20230328/DJI_Mini_3_User_Manual_v1.0_EN.pdf |
