Pair function will not start
759 4 2023-4-17
JKoster
After the RC was updated with new software the connection between RC and aircraft is lost. I need to pair the two.
For some reason the Magic air 2 will not go into pair mode.
After pressing the power button for at least 4 seconds until sound confirmation. After 4 seconds simply nothing happens.
How can this be resolved?
2023-4-17
DowntownRDB
Flight distance : 1722 ft
You might need to refresh the firmware to see if that will help.
2023-4-17
JKoster
thank you but I already did and that did not make any difference
2023-4-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. As you mentioned that this issue occurs after updating the firmware on your RC, kindly download the DJI Assistant 2 software on your computer and please update/refresh the firmware of the aircraft and also the RC then check if the issue persists. If you still experience the said issue, kindly please provide us a short video recording showing the linking issue so we can check it here. Keep us posted. Thank you.
2023-4-17
DowntownRDB
JKoster Posted at 4-17 11:43
Sorry to hear that did not help.  You might have to send it in for diagnoses.
2023-4-18
