Pilot 2 does not show total flight time for SOC and Oblique tasks
1467 9 2023-4-22
PaulKofi
Mexico
Hello,
I just noticed that when looking at a Smart Oblique Capture mapping task, the info pertaining to this task only corresponds to first plan of a 2 plan task. IN SOC, Pilot 2 creates 2 perpendicular S flight plans to cover obliques in 4 directions... In my attached example, the task (ParqueFundidora) only shows flight time, distance and Number of photos for plan 1 of a 2 plan task! Very misleading as you would think that this task will take about 45 mn while in fact it will be something like 1h30! Please correct, and show info for each plan of SOC mapping task. Same remark applies to Oblique task (even worse as it shows info for only first plan of a 5 plan task! Also for linear task,  I guess...
I can confirm that for linear the flight info is correct. That is it reflects the total distance , No of photos and time of the various plans (bands) forming the task. IN example shown, the distance is 5600 m while the center line of linear task is around 1700 m. My task is covered by 3 lines and has 3 bands or plans....But please, do fix the bug in flight info for Mapping Smart Oblique Capture and Oblique tasks!
2023-4-22
Johnnokomis
Flight distance : 13440348 ft
I also dislike how you can't get this information without first saving the mission and exiting the flight planning screen. Before this latest update your time and distance would update in real-time as you adjusted the mission.
2023-4-23
Pro88Cro
Flight distance : 320043 ft
Croatia
+1 for that
It should show cumulative + single flight
2023-4-23
GEORobson
Flight distance : 411289 ft
Poland
Johnnokomis Posted at 4-23 18:06
2023-5-3
djiuser_xp22w5ZmmFMg
Flight distance : 1846860 ft
Definitely! DJI Pilot original used to give you flight times etc as you created your polygon which was really helpful.
2023-6-29
Johnnokomis
djiuser_xp22w5ZmmFMg Posted at 6-29 14:10
I don't know what DJI means in the update from a few days ago when they say Optimized some of the DJI Pilot 2 information such as prompts. I orginally thought they ment they had brought this feature back. It was not however. I still can't find a single thing that they have optimized.
2023-6-29
GeorgeEV
Flight distance : 1608 ft
Greece
Johnnokomis Posted at 6-29 15:13
So you did the update and everything is like before?
I also had misleading information on a SOC task. It showed only the info of the first task.
I also agree that the info must be shown realtime without having to save the mission and exit to see it.
2023-6-30
Johnnokomis
GeorgeEV Posted at 6-30 05:19
Yes it is exactly the same as before. C'mon DJI quit trying to fix stuff that isn't broken. There are plenty of things that are actually broken that need worked on. You're moving in the wrong direction.
2023-6-30
djiuser_AJmEIlf6kr6y
Flight distance : 5375315 ft
Israel
Hi guys,
Any word on that issue?
2023-8-27
fans2060b3fb
Malaysia
Why when i use Oblique Mode mapping we can see the arm inside photo, i,m using M350 with P1-35mm camera
2-6 13:29
