LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
Don't expect to get any technical help from DJI regarding the Terra software here, the bots don't know anything about it.
1/ If you are talking about the background map of DJI Terra yes it is normal. The aerial view is provided by Google, it is more or less well aligned in places so there may be small shifts.
2/ What are you trying to open the TIF with? You can try with QGIS, if you give it time it should be able to open anything. Then you reduce the resolution or you fragment it to make it compatible with less powerful machines. If you can't, send it to me by google drive, I'll try to open it and fragment it.
3/ When you talk about model, is it a mesh or a DEM raster? If you're looking to make mesh, I don't know because I've never tried with Terra. If we talk about the DEM then it is not normal at all.
And you must be able to move your thread in "pro system", it is more appropriate. You might get more response.
