What mode am I in?
1210 6 2023-5-3
Staffydog33
Flight distance : 1348881 ft
CE or FCC
any help much appreciated
Matt
2023-5-3
KLRSKIR
Flight distance : 28675886 ft
Handy guide.
https://www.youtube.com/shorts/5q2wxdySPWc
2023-5-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Based on the image that you provided, it shows bandwidth under the current frequency is 5.8 GHz. Please note that not every country’s certification belongs to one of the FCC/CE/SRRC, we just make sure that the US uses FCC, Europe, and UK use CE, and China uses SRRC. No matter which certification type the country is, it doesn’t mean we must use the standard of that certification. We just make sure the maximum transfer power of the remote controller applies with the local law, but won’t reach the largest permission. The maximum transfer power of our produce is decided by DJI and is restricted by local law. Should you have other inquiries, please don't hesitate to reach us. Have a nice day ahead!
2023-5-3
DAFlys
You're in FCC mode.
2023-5-4
Staffydog33
DAFlys Posted at 5-4 00:23
You're in FCC mode.
Thanks, much simpler and perfect reply, genuinely all I wanted to know. thanks.
Mini 3, (non pro) with dji rc with screen and permanent FCC mode
2023-5-4
DAFlys
Staffydog33 Posted at 5-4 07:48
Yep,  I had guessed that.   just make sure you check the other forum before you update or you might loose it.
2023-5-4
djiuser_L6GgpvQzPasn
Flight distance : 87208 ft
Brazil
Hello, I bought my DJI mini 3 on a website in the Netherlands and I’m using the drone in Brazil. I’m having trouble with the communication signal between the drone and the remote control. It seems to me that the transmission is always in CE mode and never in FCC mode. Even though the drone was purchased in Europe, is it also compatible with FCC mode? Thank you.
2023-6-14
