RC Pro Battery Level Indicator
1311 10 2023-5-5
ChrysalisBSL
Flight distance : 7349 ft
Hi, has anyone come across the following issue.
I have a fully charged RC Pro controller but the second led does not light. When I press the power button briefly only led's 1,3 and 4 light. The same is true when I power on the controller.
Attached is photo of problem.
Missing LED
Missing LED
2023-5-5
frankymusik
Flight distance : 27841053 ft
This is a hardware defect, definitely!
I had something similar with the Motion 2 controller, which was then exchanged by DJI....
2023-5-5
DJI Tony
Hi, ChrysalisBSL. Thanks for reaching out, and we're sorry for the inconvenience. The LED appears to be malfunctioning but usually, this does not affect the normal usage of the remote controller. However, if you feel that this needs repair, feel free to send it back to us. You may submit a repair case at (repair.dji.com) or contact Customer Support at (support.dji.com). We appreciate your understanding.
2023-5-8
gulfpre
Flight distance : 2885656 ft
I'd send it in for repair. ;)
**Edited. I've//I'd
2023-5-8
frankymusik
gulfpre Posted at 5-8 10:28
I've send it in for repair. ;)
Same problem...
... or same boy...???   (... new username?)
2023-5-12
gulfpre
frankymusik Posted at 5-12 22:03
Same problem...
Auto correct got me. was supposed to say: "I'd" send it in.
2023-6-15
fans9e6c3c4e
Flight distance : 164964 ft
Same problem here
2023-6-15
djiuser_zKR5HFX3a2EC
Flight distance : 474537 ft
The lights shows how much % you have does not effect proformance. Is it under warranty? If so can send it in. If not, it's not worth the cost to repair a tiny led light.
2023-6-15
frankymusik
gulfpre Posted at 6-15 06:29
I see...
2023-6-16
frankymusik
djiuser_zKR5HFX3a2EC Posted at 6-15 16:13
Maybe  --- maybe not...
2023-6-17
FDDX
Flight distance : 179068 ft
Philippines
Im having the same issue. Missing the 3rd green led
How can I send this back to have it fixed?
Thanks!
3-14 07:06
