Ramjet1965
Flight distance : 176309 ft
Hi, New to posting so sorry if I make a mistake, or post incorrectly.
I see other similar posts but not sure if my situation is the same.
I flew starting with a fully charged battery for approx 3 mins bringing Battery to 83% then another flight 2.5 mins taking the battery to 69% , Then a supposedly quick vertical to about 20m to do 1 Pano shot from a lookout point, Battey was 50% at take off, Looking at the log , the Battery voltage dropped from 14.9v to 12v in a split second at the 2.5second mark, Once I reached the height of about 23m I sticked forward to move the drone out of the sun before intending to rotate for the footage. Also the log for the 1st flight seems to have a bit of weird battery info showing a drop then an increase? The % does not seem to change with the voltdrops either.
The Drone just dropped to the ground, smashing the gimbal and landing gear.
I have had the drone approx 8yrs ish, cant remember exactly, Have not used it a lot (3 x Batteries, 16, 21 cycles and the relevant battery 18 cycles) Total for the drone since new.
What do you think caused the drop from the sky?
What Voltage does the drone cut or switch off at?
All software and firmware is up to date and no warnings came up.
I was using Litchi
I know we should use a fully charged battery each flight but after just a few minutes total flying on that charge, I would not expect to have the drone cut out.
If this is a battery issue, How can we check batteries for possible issues? These Batteries were nearly $300 each at the time so I want to check them properly before discarding them.
1st Flight log - https://www.phantomhelp.com/LogViewer/38MU7QZ468L86GKVR58N
Crash log - https://www.phantomhelp.com/LogViewer/1Y7W55CLFRHJR20ZNV8L
Any help would be really appreciated, Thanks
