Dji RC
604 2 2023-5-7
djiuser_iWqJuha18VI1
Having issues with the Dji Rc . I seem to lose control of the drone completely when I take off, in which case I have to switch off the controller for it to land itself. In other cases I lose the yaw control of the drone and it moves ever so slowly slowly. To resolve the issue I need to land the drone and switch everything on and off again. The reliability of the rc is worrying.
2023-5-7
Suren
Flight distance : 13498560 ft
New Zealand
Check that you have the RC set to the correct mode example mode 1/2 or 3. Also do a stick calibration of the RC.
2023-5-7
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Kindly refer to the response of Suren on post #2 about. If the issue persists, you may try to re-link the aircraft to the controller and update the firmware of both using DJI Assistant 2 software (download it using this link: https://www.dji.com/downloads/so ... sumer-drones-series) then see if there are some changes. Please keep us posted. Thank you.
2023-5-7
