Color and Grading Test - What do you think?
2379 21 2015-8-25
Paniza
Flight distance : 1411801 ft
Each scene will change after 5 seconds. First land, then skies.
What do you think about the final transformation of each scene?
Thanks.
------------------------------------------------   Signature    --------------------------------------------
If you are going to buy DJI products and want to help me, please use this link: BuyDJI.ca
2015-8-25
Willie Wonka
Very nice transformation, what did you use to make this transition ?
2015-8-25
Paniza
Willie Wonka Posted at 2015-8-26 05:32
Adobe Premiere.
Then, changed Opacity on different layers.
On YouTube, check the description. There will be a link to a tutorial that I based the tests on.
Actually, there it is:
Frederick is active in this forum.
2015-8-25
Willie Wonka
Paniza Posted at 2015-8-26 10:04
Adobe Premiere.
Thank you for the reply I'll check it out
2015-8-25
SpunOne69
Thanks...I'm just learning Premier right now, I hope I can come up with something half as good
2015-8-25
DroneMania
The Shot of the sky around 17 seconds... Amazing.
2015-8-25
AlmostTan
Flight distance : 118665 ft
This may be the best thread ever just learned so much. Thanks for sharing and great work grading!
2015-8-25
innovativethink
I like it, where can I get that background audio?
2015-8-26
paullindqvist
Sweden
Looks better, but i would use masks so that you don't get a underexposed image of the ground and slightly overexposed on the sky. Some shots the contrast will work, but a for a base grade it's not always suitable.
2015-8-26
Paniza
innovativethink Posted at 2015-8-26 22:22
I got of YouTube. Unfortunately don't remember from where.
The name of the song is parallel.
If you find it, please let me know.
Thanks.
2015-8-26
Paniza
paullindqvist Posted at 2015-8-26 23:42
Looks better, but i would use masks so that you don't get a underexposed image of the ground and sli ...
Yes you are correct.
I had to reduce exposure of the sky but ran out of time.
2015-8-26
Paniza
Found it:
2015-8-26
paullindqvist
Sweden
Paniza Posted at 2015-8-26 18:34
The use of gradual ND's (which the guy in the video use)  is nice for static camera shots where horizon is centered in the frame, but won't work very well when you move the camera..
2015-8-26
Paniza
paullindqvist Posted at 2015-8-27 01:40
The use of gradual ND's (which the guy in the video use)  is nice for static camera shots where hor ...
It does actually. The biggest work on my test was the last shot.
You create a path with few points and move it around as the camera moves. Premiere helps you with that.
That is similar to the work he did with the water.
2015-8-26
paullindqvist
Sweden
Paniza Posted at 2015-8-26 20:44
You create a path with few point ...
Think you misunderstood, i meant that the gradual  physical ND filter is less effective (as the guy stated he used in the Youtube video) unless you have you'r horizon at the same level in the frame.
Premiere CC 2015 offers new color correction  tools, which is nice if you'r new to grading and don't need a full grading suite. But it simply can't match SG for grading and masking. The mask needed is simple and won't take much time for SG to calculate.
2015-8-26
Paniza
paullindqvist Posted at 2015-8-27 03:54
Think you misunderstood, i meant that the gradual  physical ND filter is less effective (as the gu ...
Yes I did misunderstood, sorry.
Not sure how the graduation is done but you definitely have a point.
SG?
2015-8-26
paullindqvist
Sweden
Paniza Posted at 2015-8-26 22:29
Not sure how the graduation is done but you definitely have a po ...
SG= Speed Grade (which is part of the Adobe CC 2015 Suite)
2015-8-26
ag0n
Flight distance : 700846 ft
I think the video was a good demonstration and I like the results.  I do think, however that the last one was a bit weak.  Perhaps it just wasn't a great scene.
2015-8-26
bill
Awesome job with the grading and thanks so much for both the link to the tutorial and the link to the song. I am just getting started with Premiere so this will be a huge help.!!
2015-8-26
Bartone
Flight distance : 53458 ft
AWSOME! Thank you so much. I've watched it twice, an I'm not a novice! However, I can't figure out how you inserted an adjustment layer - I'm on CS 6, perhaps it's not available on CS 6? Photoshop, easy, PPro, a bit confusing.
Thanks
bartone
2015-8-27
Paniza
Bartone Posted at 2015-8-28 00:53
AWSOME! Thank you so much. I've watched it twice, an I'm not a novice! However, I can't figure out h ...
Try this...
Do you know the window that has all shots, music and all that you can use in the movie?
There, create new item, adjustment layer.
Then drop the layer in one of the video channels. Must be above of the other channels.
But yes, takes few hours to get used to Premiere but, the more I learn, the more I like and the more things make sense.
2015-8-27
innovativethink
Paniza Posted at 2015-8-26 10:29
Found it: https://www.youtube.com/watch?v=je9bnuIqVVc
Thanks, I never knew free music was available.
2015-9-1
