Madcom
Flight distance : 23898 ft
Hello I've been trying to update my Mini 2's firmware for weeks now. But I always get the error 0x1103a0090012
I also had to download and install the DJI Fly app manually because the error code also came up when searching for updates.
I've already tested different WLANs, it doesn't work with mobile data either.
It doesn't work with DJI Assistant 2 either. As soon as I connect the drone to the PC via USB cable, the drone would not turn on. It's just only charging. Tested on two PCs, tested different USB ports and cables. The controller was recognized on the PC without any problems and I was able to update it.
Firmware on the drone is: 01.06.0200 DJI App: 1.10.1 (1005-official)
