Mini 3 Pro Moving forward when taking off
3308 30 2023-5-16
djiuser_WqSTnmwIKhL9
Flight distance : 344879 ft
Singapore
I just got a mini 3 pro and I realize that the drone actually move a little forward when taking off. Is that normal?
2023-5-16
WN1X
Flight distance : 37884 ft
It might be normal. Does your drone maintain it's position when hovering after the takeoff has completed?
2023-5-16
Sean-bumble-bee
Flight distance : 15997 ft
Try doing a google, I seem to remember something about this.
That said, when hand launching a Mavic Mini or mini 2 I often see some initial horizontal drift, quote often they then slowly move back towards the take off point. You just have to make sure there is room to accommodate any such driftt or be ready to counter act it with GENTLE joystick input.
2023-5-16
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Yes, during takeoff, it shifts forward a little by 0.5-1 body
2023-5-16
Singapore
WN1X Posted at 5-16 05:18
Yes, my drone maintain it's position when hovering after the takeoff has completed...
unfortunately i am not able to upload video here...
2023-5-16
Singapore
I am not sure. But does this got to do with Calibration of IMU and Compass?
I have a Mini 2 as well. But it doesn't have this issue...
Could it be also because the size of Mini 3 pro is larger in size that causes this?
I am trying to list down all possible cause
2023-5-16
Ranjan
India
djiuser_WqSTnmwIKhL9 Posted at 5-16 19:02
Upload your video on youtube & share its link here in the forum
2023-5-16
scuba8085
Singapore
i will try to re-calibrate my mini 3 pro and update here
But I think it could probably be the same if all feels that this is normal
2023-5-16
DJI Gamora
Hi, djiuser_WqSTnmwIKhL9. Thank you for reaching out. Can you please provide us with a video of the operation for further checking?
2023-5-17
Burt37
Flight distance : 4009 ft
Mine does move forward, but not by much.. I would say maybe 5-10cm forward. It also depends on how level and windy it is when you take off.
2023-5-17
fans78860db9
Singapore
scuba8085 Posted at 5-16 23:34
After re-calibrating the IMU and compass, I felt the same. Still the drone move forward. Like before not much thou, about half a drone length?
2023-5-17
fans78860db9
Singapore
DJI Gamora Posted at 5-17 00:30
How do I upload the video to this forum?
2023-5-17
fans78860db9
Singapore
Burt37 Posted at 5-17 01:52
Not much wind. I tried in the same location using my mini2. Doesn’t have this moving forward effect.
2023-5-17
Leo Guerra
Flight distance : 3593022 ft
Brazil
You probably took off without waiting for the GPS satellites to pick up.
2023-5-17
fans78860db9
Singapore
Leo Guerra Posted at 5-17 04:27
The satellite was locked at 30. So shouldn’t be a problem
2023-5-17
fans78860db9
Singapore
https://www.dropbox.com/s/9tuf0wudtyk2kkk/Mini3pro_forward.mp4?dl=0
The above link shows the drone move forward...
Let me know if it is normal?
2023-5-17
Hullie
Flight distance : 3356657 ft
That's normal. I wouldn't worry about it.
2023-5-17
Burt37
fans78860db9 Posted at 5-17 03:29
Let's try again. What is your concern? That the drone may be faulty?
We are dealing with 4 rotors controlled by a chip that need to do complex calculation based on the data that receives from the other chips to hover in one spot... Try that yourself with a single rotor helicopter without any aids and see how easy you can manage that.. You need to allow for some small adjustments for the few milliseconds that it takes the CPU to work out what it is happening...
If your drone is stable AFTER TAKE OFF, your drone is fine.. If it keeps moving around in no wind and with full GPS signal, then you may have a problem...
2023-5-17
scuba8085
Singapore
Thanks Guys!
2023-5-17
DJI Gamora
fans78860db9 Posted at 5-17 03:28
Hi, fans78860db9. We have sent you a PM regarding this. We already received the link and forwarded it for further checking. We'll keep you posted. Thank you.
2023-5-18
DJI Gamora
fans78860db9 Posted at 5-17 06:02
Hi, fans78860db9. Thank you for patiently waiting. We now received feedback from our relevant team. Please check the following:
1. Please confirm if you have replaced the propellers. If yes, then it is possible that the arms were slightly deformed when the propellers were replaced, so the propellers' surface (rotating surface) is uneven.
2. The issue may be also caused by loose propeller screws. Safely land the aircraft immediately and check carefully to see if the propeller screws are tightened properly.
If not, then tighten the screws properly. Make the aircraft take off and hover for 30 seconds, then make the aircraft take off another time to see if the issue has been solved.
Please keep us posted. Thank you.
2023-5-22
fansb8cc68a0
Singapore
DJI Gamora Posted at 5-22 06:35
Hi, thanks for your follow up and suggestions.
1. I have not replaced the propeller before. The propellers was originally from the drone when I unboxed it.
2. I will try to tighten the screws on the propeller to see if it is loosen during the flight. But so far I only did about 5 flights.
Anyway, once I try it on your second suggestions, I will revert back here.
Just for your info. I did seen a video before I. YouTube. One of the video also had similar take off… let me post it up here.
2023-5-22
fansb8cc68a0
Singapore
fansb8cc68a0 Posted at 5-22 07:00
Check out this link from a YouTube:
https://www.dropbox.com/s/717ey54uyr9c6ln/takeoff.mp4?dl=0
The drone actually have the same forward take off…
2023-5-22
Ranjan
India
Try using the automated take off by pressing the button on the screen then record a video, don't use the sticks at all.
Does it still do forward moment?
How are wind condition when you fly drone?
2023-5-22
fansb8cc68a0
Singapore
Ranjan Posted at 5-22 08:19
Yes, I use automated take off and no or low wind condition.
2023-5-22
DJI Gamora
Thank you for the reply. Please keep us posted.
2023-5-24
socrbob
My mini 3 pro jumps forward 2 or 3 inches when it takes off, no wind, flat ground. Interested in any thoughts or suggestions on how to cure this? Do not have this behavior with my mini 2.
2023-8-10
DJI Tony
socrbob Posted at 8-10 18:10
Hello there. Will you be able to post a video here? You can save your video to your Google Drive or Youtube and then paste the link here. I appreciate your patience. Have a great day ahead.
2023-8-12
ianzaft73
Philippines
We have the same problem. I make sure to take off my 3 pro in widely open space because I'm scared of that forward effect..
3-30 02:47
DJI Tony
ianzaft73 Posted at 3-30 02:47
Hi, ianzaft73. Sorry about the trouble. Have you already tried DJI Gamora's suggestion above in reply 21#? Please keep us posted. Thank you for your patience.
3-30 02:53
sticcckkko
Flight distance : 251273 ft
I'm sorry this doesn't have to do with this thread and I'm sorry but earlier I was flying mine and I saw another blue arrow like mine approach mine way faster than I could and th3n like morph into mine and then started flying all crazy like wtf was that.
4-1 10:31
