The firmware was updated to the latest version on the contoller and the drone and the goggles.
The propellers are installed properly too and i did calibrate the Sensors too.
The Flyzone was a Warningzone but the drone did the same thing in a free flight zone.
There was a low amount of wind up to no wind.
Hi there. Thank you for reaching out and we do apologize for the inconvenience. Can you please double-check or inspect the propellers if there is damage? If yes, please replace it and see if the issue persists. In addition, please make sure to attach the propellers with red rings in the center to the motors with red rings, and attach the ones without red rings to the corresponding motors. You may refer to the tutorial below and please start at @0:16 for guidance on how to properly install the propellers. Please let us know. Thank you for your valued support.
