DJI Paladin
Hi there. Thank you for reaching out. You may refer to the information below about the charging protocol and maximum charging power supported by the DJI Mavic 3:
USB-C port of DJI Mavic 3: When the USB PD3.0 PPS protocol is supported, up to 88W charging power can be achieved. When the USB PD3.0 protocol is supported, up to 55W charging power can be achieved.
DJI Mavic 3 Charging Hub: When the USB PD3.0 PPS protocol is supported, up to 88W charging power can be achieved. When the USB PD3.0 protocol is supported, up to 65W charging power can be achieved.
DJI RC Pro: When the USB PD3.0 PPS/USB PD3.0 protocol is supported, up to 45W charging power can be achieved. When the QC protocol is supported, up to 24W charging power can be achieved.
The DJI 65W Portable Charger provided with the DJI Mavic 3 supports the USB PD3.0 PPS protocol, and the Intelligent Flight Battery can be charged at 65W. The charging power of the DJI RC Pro is 45W, which is the maximum power accepted by the device. To charge the aircraft and remote controller simultaneously, use the USB-C cable to connect the aircraft first and then the remote controller via the USB-A port. The USB-C output power is 55W and the USB-A output power is 10W. As the PD fast charge protocol is compatible with lower versions, the DJI 65W Portable Charger provided with the DJI Mavic 3 can also be used to charge other electronic devices that support the PD protocol. |
