Choppy Video
850 7 2023-5-29
djiuser_dp99qsuib95l
Flight distance : 331614 ft
Hello,
I am facing an issue of in-flight choppy video recording with my DJI Mini 2. It happens in almost every recording and multiple times, especially when the drone is moving either pan with gimble at 0 deg or gain altitude with gimble at -90 deg.
I've attached the sample recording and also the firmware details, along with the memory card which I use. Request support in resolving this.
2023-5-29
nazgull
Perhaps try a different memory card, if possible. That would be the simplest test, before suspecting the drone.
There are many fake memory cards around, especially in the higher capacities. Even Amazon has been known to sell them, so if yours was a "really good deal", that's an avenue to investigate.
2023-5-29
blue_canyon21
Flight distance : 23370489 ft
That SD card is very inadequate for this application. It has a read speed of 95MB/s and write speed of 90MB/s.
You need one that has, along with U3, at least A2 and V30 ratings as well. These ratings will give around 200MB/s read speed and 140MB/s write speed.
If you're looking for a budget friendly card that works well with the Mini 2, I have this one and it works great: https://www.amazon.com/SanDisk-I ... apter/dp/B0BFXLT123
2023-5-29
DJI Tony
Hi there. Thanks for reaching out, and we're sorry for the inconvenience. Does the issue also show on the original video? Kindly upload a copy of the original file on this link for further checking. Thank you.
2023-5-30
Montfrooij
Flight distance : 2560453 ft
I don't think this is due to the SD card.
Do you have more examples, also with the gimbal NOT at 90 degrees (this is a known issue with the Mini2, which can't be solved because of the way the Mini 2 is constructed)
2023-6-2
nazgull
Montfrooij Posted at 6-2 00:53
Yes, you are probably right. I get the odd jump in video too but not quite so bad as the example. Per the SD card, trying at a lower resolution (1080p, 30fps or lower) would be an easier test. Just about any card can handle that.
2023-6-2
Montfrooij
nazgull Posted at 6-2 06:07
If it was the SD card, there would be other artifacts probably.
2023-6-2
HerbA
Flight distance : 1209682 ft
Did not know this (stutter issue when recording looking down) about the Mini 2.
I have a 4k video looking straight down BUT not moving (watching aligator swim through the frame) and no issue which I was going to share, BUT, I realized it has a frame-rate of 23.98.
Will go out and try again to see if my Mini 2 is showing the same signs of stutter at higher resolution. Would rather know it and avoid if it is the case.
Thanks for the heads-up.
2023-6-6
