Mavic 3 jerky gimbal movement during way point mission
670 1 2023-6-7
Jnortheast
Flight distance : 241220 ft
I've been excited to test out way point missions to fly repeatable orbits around houses being built to be able to fade between the different stages of the build over months.
I setup a mission with about 8 way points as I orbited the house and maintained the camera pointing to the house. As the mission flys, when it hits some of the way points, the gimbal glitches for a frame or two making an extremely small pan correction. It does it 4 or 5 times during the mission and makes the footage unusable.
I tried recalibrating the gimbal, made sure I've got full strength signal, but no luck.
Has anyone else experienced this, or is it just me?
2023-6-7
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm if this issue only happens during waypoints? In addition, kindly please send us the video showing the issue so we can check it further. Please keep us posted. Thank you for your understanding and support.
2023-6-9
