Sean-bumble-bee
Flight distance : 15997 ft
Do you have the cable plugged into the correct socket on the controller? One apparent socket is just an empty hole, the other socket contains the parts of a female USB-C socket.
Secondly and only applicable if you have a USB-C phone, do you have the correct end of the cable plugged into the correct socket? If you look closely at the outer face of the cable plugs one plug has the image of the controller on it.
Having watched the video I would, if applicable, be inclined to check that the cable plugs are the correct way around. If they are then check whether or not the phone behaves in the same way when connected to a computer. If the phone has a micro USB connector then my first suspicion would be a dodgy socket on the phone. Have you tried a different phone that has the same type of connector?
