Tello: Cancel Automatic Positioning
562 1 2023-6-16
JaMePa
When you are connected to Tello (NOT Edu) from an application developed in Python, I notice that the light in the room is very important in the automatic positioning of the drone. The problem is that if there is not a lot of light, the drone does NOT respond to the instructions I send to it and moves on its own discretion. All this does NOT happen with the same code but flying outdoors. Do we have a way to cancel this automatic positioning and correction by command?
2023-6-16
DJI Paladin
Flight distance : 318 ft
Hello there. Thank you for reaching out. You may directly contact Tello support using this link https://www.ryzerobotics.com/support . They will further help you with your concern about this drone. Thank you for your understanding.
2023-6-17
