Skippyio
Flight distance : 365938 ft
Hi - I have an issue with momentary loss of RC link when using the Controller 2 with Goggles 2 and Goggles Integra with the DJI Air Unit/Air Unit Lite. It is apparent even in remote areas where no interference is possible and no other RC aircraft are in operation. There are about 10-20 breaks per minute of flying even when flying in close proximity. The updated air unit software has improved the condition but it is still a problem. Goggles firmware = 01.05.00.00 Air unit = 01.01.00.00 Remote Controller 2 = 02.00.07.00. The issue is constant, even when flying close by with the signal status bar showing full signal strength. The breaks are clearly displayed in the Betaflight black box viewer. The breaks in the RX signal are usually around 100ms or less but sometimes, when greater you will see that stage one failsafe is invoked, in this case, triggering angle mode and hover throttle. Stage two is set to RTH after 1 sec and occasionally the break is long enough to trigger this. During a long break, the goggles OSD shows 0 bars in the RC link strength which lasts for about 3 seconds until signal and pilot control returns. I have not had a long break since updating the controller to .07. Luckily I am using Betaflight version 4.4 and the GPS has saved the craft several times. Had failsafe been set to 'Drop' these would have been several crashes. I have tried substitute air units, goggles and controllers so hardware faults are eliminated from the equation.
